2010 Interstate 16'x7' and 7 1/2' tall inside, dual axle trailer with ramp door and side locking door with well over $13,950 invested for ONLY $7,500 OBO, this trailer is an AWESOME deal for someone. I easily pulled this trailer with a 1/2 ton Chevy Silverado. It only weighs 2,590 lbs. empty and can hold a cargo weight of 4,421 lbs. with a total GVWR of 7,000 lbs.
NO reasonable offer will be refused but NO low ball offers will be considered at all. I've done a lot of research and have set the price at a very low, fair price. This is just an AWESOME trailer.
VIN # 4RACS1629AC025112 MODEL # I716TA2
You'll be able to use it for a couple years and still get every penny back if you re-sell it.
The trailer has a 13,500 btu air conditioner installed as well as the electrical breaker box and marine (screw on) electrical hook ups. It's a 30 amp electrical system but it will come with ALL adapters to hook up to 30, 40 or 50 amp hook ups as well as 110 volt plugs.
The floor, ramp door and about 4 inches up the walls Rhino lined. This makes it very easy to clean and pressure wash inside. The walls have whiteboard to be waterproof as well as to be able to write on with dry erase markers. This makes writing the race order, friends phone numbers, autographs, etc. right on the wall and then can be easily erased.
The whole inside of the trailer has been taken apart and insulated with foam, then double bubble radiant barrier, then the 3/8" plywood and finally finished with whiteboard for waterproofing as well as to be able to write on the walls with dry erased markers.
* 13,500 btu A/C with optional heat. This A/C works so well, you can make the trailer 32 degrees inside when it's 105 outside if you want. The trailer is VERY well insulated too.
* 22" TV with DVD and computer hook ups with a 75 mile radius TV antenna.
* 900 watt microwave.
* Under counter stereo/cd player
* Upper and lower cabinets for storage diamond pattern metal.
* 3 helmet shelf with a 10 position hanger rack for jerseys and gear.
* broom rack for cleaning off the concrete pads in the starting gates.
* Go Kart wall mounted tire rack
* All cabinets were made by Universal Trailer Outfitters @ PitProducts.com
* TV antenna and electrical hook ups. The outdoor electrical hook ups are wired to a switch inside the trailer so you can hook up outdoor lights and can turn them on and off from inside.
* 2 tracks of e-track along the entire length of both walls and 3 tracks along the entire length of the floor.
* 4 custom length aluminum load bars for the e-track from Lodi Metals, Inc.
* There are many, many different e-track clips and straps included. The loading options are limitless.
* The load bars are used to make bunk beds for sleeping at night and they can be used to make a platform over your bikes, karts, etc. so you can load your gear all the way up to the ceiling.
* The Rigid - Yamaha powered 8,500 starting watt, 6,800 running watt generator with 4 120 volt plugs, 1 120 volt / 240 volt GFCI plugs and one 30 amp plug...very, very low hours
* 3 very bright, but very low watt lights inside the trailer. They put out about 400 watts of light but only use 51 watts total power.
* Trailer comes with four 205/75 R15 tires 2 with 90% tread left 2 purchased in October 2015 and one spare tire.
* 4 tire covers
* 12 volt lights inside and outside the trailer for use when the generator is not hooked up yet. These lights work well enough to see everything you need too.
* Kobalt 3 drawer with tip lid locking tool box mounted to the top of the lower shelving unit.
* 2 sand pads and stabilizing stands on rear of trailer.
* Front 3500 lb electric jack, 12 Volts.
* Electric brakes saefty brake.
* Champagne colored trailer with LOTS of diamond plate all around the trailer.
* Torsion suspension.
* All LED driving lights on trailer.
* 6 plug 110v power strip inside trailer.
* 2 plug 110v outlet by side door on inside of trailer.
* Paper towel holder.
* Spring assist rear ramp door makes lowering and raising door VERY easy.
* 4 Large D-rings mounted in the floor to the frame of the trailer for tying down heavier loads.
* 2 Side vents. One upper left side and one lower right side.
* Plastic Strip Curtains across back door to help keep trailer cool when door is open
There is plenty of room. With the high ceilings, this is one of the only trailers that you can easily drive in a Rhino or similar type ATV.
HAVE A LOT OF PICTURES, REPLY TO EMAIL LISTED BELOW AND WILL SEND THEM TO YOU
CONTACT
Mobil: 214-869-4266
Email: Trekker.baitup@gmail.com
Race Trailer - 2010 Interstate 16'x7' and 7 1/2' tall
Michael baitup
