https://www.facebook.com/marketplace/it ... 720359067/
2018 Intrepid Cruiser chassis (30mm) with only 7 race weekends on it. Not crashed, frame is straight. Run with frame guards on it.
Woltjer prepared and dyno tuned X30 Senior engine. Only 7 hours on the engine since full rebuild by Woltjer.
Comes with lots of parts:
Mychron4 2T, with EGT, water, and RPM sensors, GPS sensor, data key, a powered hub, and an infrared sensor
1x set of Douglas wheels for rain tires with MG rain tires
2x set of Douglas wheels for slicks with Evinco Red tires (the ones mounted on the chassis plus another set. Each set of tires is only a session or two old.)
12x rear sprockets ranging from 76t to 86t, some new and some lightly worn. Some are Ergal too.
Some front sprockets (forgot to check my inventory of these, I think I have 2x 11t and 1x 16t)
5x NGK BR10EIX Iridium Spark Plugs, new
1x spare starter motor
1x Spark plug resistor cover, new
1x Clutch drum
2x RLV gold chain, lightly worn
1x Brake rotor/rear sprocket guard
1x Battery Charger
1x oversized Champion radiator (normal IAME radiator also included)
1x radiator mounting clamp
2x water pump pulleys
1x Set of spindle pills (for camber/caster setup)
4x spacers for front end
Exhaust flex material
Exhaust sleeve material
Throttle cables
Fuel line
3.5 sets of starter motor brushes
1x carb stud set
1x carb gasket
I also have a bunch of ballast that I’m willing to sell, but which is not included in the asking price.
Kart is located in Norman, Oklahoma. Can email more photos.
Text 973-738-6591.
2018 Intrepid Cruiser Racing Kart with Woltjer X30
Sarin Kodappully
